树莓派录音遇到的问题
橘子 20cm • 2020-04-20 • 5581 次点击
使用树莓派录音,调用百度API进行语音识别,编程语言是python。之前是可以用的,今天突然报错了。求大神帮忙看看要怎么解决
xcb_connection_has_error() returned true
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.front.0:CARD=0'
ALSA lib conf.c:4568:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5047:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 934
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:5036:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM bluealsa
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.bcm2835_alsa.pcm.iec958.0:CARD=0,AES0=6,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM iec958:{‌AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->capture, inParams, self->primeBuffers, hwParamsCapture, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2719
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
File "main1.py", line 272, in <module>
Monitor()
File "main1.py", line 232, in Monitor
frames_per_buffer=CHUNK)
File "/usr/lib/python3/dist-packages/pyaudio.py", line 750, in open
stream = Stream(self, *args, **kwargs)
File "/usr/lib/python3/dist-packages/pyaudio.py", line 441, in __init__
self._stream = pa.open(**arguments)
OSError: [Errno -9997] Invalid sample rate
Spoony 小组长 2020-04-20
看日志是没找到声卡。
橘子 20cm 2020-04-20
@Spoony 但是 如果在命令行直接输入命令:arecord -D "plughw:1,0" -f dat -c 1 -r 16000 -d 5 test.wav 是可以正常录音的。
@橘子 不清楚了
RaspiSQH 123.7m 2020-04-20
你不给程序,我就只能盲猜了。我猜是用户问题,可能是有一次没加或多加sudo导致的。
橘子 20cm 2020-04-22  ♥ 1
已解决问题。使用pyaudio进行录音时,数据缓冲块CHUNK的值不能大于512,否则就会报错:OSError: [Errno -9997] Invalid sample rate
AntaresShao 35cm 2021-06-13
@橘子 这个不能大于512到底是因为什么呀?最近搜网上的1例程看到好多都是取得1024。我的也是大于512就失败,我用的4B 2G RAM。
