树莓派无法成功安装php
橘子 20cm • 2020-04-12 • 2981 次点击
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-common armhf 7.3.11-1~deb10u1
404 Not Found [IP: 93.93.128.193 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-json armhf 7.3.11-1~deb10u1
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-opcache armhf 7.3.11-1~deb10u1
Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-readline armhf 7.3.11-1~deb10u1
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3-cli armhf 7.3.11-1~deb10u1
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf libapache2-mod-php7.3 armhf 7.3.11-1~deb10u1
Err:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf php7.3 all 7.3.11-1~deb10u1
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-common_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-json_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-opcache_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-readline_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3-cli_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/libapache2-mod-php7.3_7.3.11-1~deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/php7.3/php7.3_7.3.11-1~deb10u1_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
求帮助!
RaspiSQH 123.7m 2020-04-12  ♥ 1
sudo apt update
沐风MWind 63.05m 2020-04-13
你换个源吧
沐风MWind 63.05m 2020-04-13  ♥ 1
# 编辑 `/etc/apt/sources.list` 文件,删除原文件所有内容,用以下内容取代:
deb http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian/ buster main non-free contrib
deb-src http://mirrors.tuna.tsinghua.edu.cn/raspbian/raspbian/ buster main non-free contrib
# 编辑 `/etc/apt/sources.list.d/raspi.list` 文件,删除原文件所有内容,用以下内容取代:
deb http://mirrors.tuna.tsinghua.edu.cn/raspberrypi/ buster main ui
橘子 20cm 2020-04-13
@RaspiSQH 谢谢您的回复 我尝试之后还是会报相同的错误
橘子 20cm 2020-04-13
@沐风MWind 谢谢您的回复 按照您说的方式修改了之后,就可以安装成功了!非常感谢!
