树莓派无法检测到摄像头
mike 25.1m • 2021-07-24 • 4498 次点击
设备: 树莓派4B, 摄像头
问题: 摄像头已经连接好,raspi-config中已启用camera。但是在执行raspistill -v -o test.jpg时输出:
mmal: Cannot read camera info, keeping the defaults for OV5647
"raspistill" Camera App (commit 4a0a19b88b43 Tainted)
Camera Name OV5647
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
无法输出图像
执行vcgencmd get_camera输出:
supported=1 detected=0
Spoony 小组长 2021-08-05
是 USB 摄像头么
mike 25.1m 2021-08-05
不是,是csi摄像头
RaspiSQH 123.7m 2021-08-06
以前用过吗?
mike 25.1m 2021-08-07
用过
