无法进入桌面怎么办?(请大佬指教)
kkk4256 • 2020-04-26 • 2186 次点击
开机之后输入用户名和密码,出现这个该怎么进入桌面?(第一次用树莓派)
raspberrypi login: pi
Passuord :
Last login: Tue Apr 21 16:06:08 BST 2020 on tty1
Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 arm
The programs included with the Debian GNU/Linux systen are free software
the exact distribution terns for each progran are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/L inux comes with ABSOLUTELY NO WARRANTY, to the extent
pernitted by applicable law.
pioraspberrypi:" $
Spoony 小组长 2020-04-26
如果使用的是 Putty,是无法进入桌面的。
需要通过 VNC 进入桌面
https://shumeipai.nxez.com/2018/08/31/raspberry-pi-vnc-viewer-configuration-tutorial.html
https://shumeipai.nxez.com/2019/07/08/set-the-resolution-of-the-raspberry-pi-vnc.html
如果使用的是显示器和键盘直接登录树莓派,可以用下面的命令进入设置开机自动进入桌面。
sudo raspi-config
