生成树莓派官方文档
Spoony 81.45m • 2024-12-05 • 1884 次点击
git clone https://github.com/raspberrypi/documentation.git
cd documentation
sudo apt install -y ruby ruby-dev python3 python3-pip make ninja-build
then add these lines to the bottom of your $HOME/.bashrc:
export GEM_HOME="$(ruby -e 'puts Gem.user_dir')"
export PATH="$PATH:$GEM_HOME/bin"
sudo gem install bundler
sudo bundle install
如果出现「Bundler 2.5.23 is running, but your lockfile was generated with 2.3.22. Installing Bundler 2.3.22 and restarting using that version.」
sudo gem uninstall bundler
sudo gem install bundler -v 2.3.22
# pip3 install --user -r requirements.txt
python -m venv env
source env/bin/activate
pip3 install -r requirements.txt -i https://pypi.tuna.tsinghua.edu.cn/simple
make
make serve_html
You can also use make to delete the build/ and documentation/html/ directories:
make clean
Spoony 小组长 2024-12-09
https://shumeipai.nxez.com/documentation/
先镜像过来,内容比较多。看看有没有小伙伴一起补充、本地化,可联系 VX:spoony002
