树莓派3B屏幕亮后只出现回收站,没有菜单栏怎么办
苏大强 • 2024-06-18 • 2016 次点击
Spoony 小组长 2024-06-20
在 /home/pi/.config/lxpanel/LXDE-pi/panels 目录下新建名为 panel.txt 文件。.config 是隐藏文件需要打开隐藏文件显示。
# lxpanel <profile> config file. Manually editing is not recommended.
# Use preference dialog in lxpanel to adjust config when you can.
Global {‌
edge=top
align=left
margin=0
widthtype=percent
width=100
height=36
transparent=0
tintcolor=#000000
alpha=0
autohide=0
heightwhenhidden=2
setdocktype=1
setpartialstrut=1
usefontcolor=0
fontsize=12
fontcolor=#ffffff
usefontsize=0
background=0
backgroundfile=/usr/share/lxpanel/images/background.png
iconsize=36
monitor=0
point_at_menu=0
Plugin {‌
type=menu
Config {‌
padding=4
image=start-here
system {‌
separator {‌
item {‌
image=system-run
command=run
separator {‌
item {‌
image=system-shutdown
command=logout
Plugin {‌
type=space
Config {‌
Size=4
Plugin {‌
type=launchbar
Config {‌
Button {‌
id=lxde-x-www-browser.desktop
Button {‌
id=pcmanfm.desktop
Button {‌
id=lxterminal.desktop
Plugin {‌
type=space
Config {‌
Size=8
Plugin {‌
type=taskbar
expand=1
Config {‌
tooltips=1
IconsOnly=0
ShowAllDesks=0
UseMouseWheel=1
UseUrgencyHint=1
FlatButton=0
MaxTaskWidth=200
spacing=1
GroupedTasks=0
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=tray
Config {‌
Plugin {‌
type=ejecter
Config {‌
AutoHide=1
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=bluetooth
Config {‌
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=dhcpcdui
Config {‌
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=volumealsabt
Config {‌
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=dclock
Config {‌
ClockFmt=%R
TooltipFmt=%A %x
BoldFont=0
IconOnly=0
CenterText=1
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=ptbatt
Config {‌
Plugin {‌
type=space
Config {‌
Size=2
Plugin {‌
type=magnifier
Config {‌
Plugin {‌
type=ejecter
Config {‌
Plugin {‌
type=cpufreq
Config {‌
Plugin {‌
type=cpu
Config {‌
Plugin {‌
type=cputemp
Config {‌
Plugin {‌
type=bluetooth
Config {‌
Plugin {‌
type=netstatus
Config {‌
重启设备,一键搞定:
字体图标大小都可以通过参数配置实现修改
