SoftDeletingScope.php line 55: count(): Parameter must be... 报错的解决方法
Spoony 81.15m • 2023-08-10 • 1842 次点击
This shouldn't be affecting 5.5 for what I've tested. We have tests for soft deleting feature (e.g. DatabaseSoftDeletingScopeTest and DatabaseSoftDeletingTraitTest) and the Continuous Integration builds for PHP 7.2 aren't failing: https://travis-ci.org/laravel/framework/builds
Note that this same line of SoftDeletingScope has already been fixed: https://github.com/laravel/framework/blob/5.5/src/Illuminate/Database/Eloquent/SoftDeletingScope.php#L55 Going back in time we can see that this was fixed in 5.4 after merging PR #20258. 😉
I solved by changing "$originalWhereCount = count($query->wheres);" for "$originalWhereCount = is_null($query->wheres)
? 0 : count($query->wheres);" in the function "callScope(callable $scope, $parameters = [])" in the file "/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php"
https://github.com/laravel/framework/issues/22162
