QQ后台来消息崩溃
xmm 30cm • 2023-04-12 • 2717 次点击 • 1 人收藏
arm QQ 最新版,前台运行QQ时正常,最小化窗口之后来消息就会崩溃,大家有这个问题吗,怎么解决的
Spoony 小组长 2023-04-12
还没有体验过 ARM QQ
观察下来消息前后的系统内存、IO、CPU 等变化看看,排除下性能方面导致崩溃的可能
alanfans 1.4m 2023-04-20
@Spoony linuxqq刚出来的时候,我用s905l3a的电视盒子玩过了,可以用,可以聊天,只是切聊天窗口的时候cpu占满,没其他问题,linuxqq x86平台还可以,只有极个别的桌面环境有问题,大部分还可以。linuxqq刚测试的时候我就在用了。用到现在。
xmm 30cm 2023-04-22
错误消息记录在~/.../crash_files/map_record.txt reg_record.txt rqd_record.eup tomb_1682153439482.txt中,这是错误的最后几行:
235,1398,Read map line: 7f88289000-7f8828a000 r--p 00021000 b3:02 3339 /usr/lib/aarch64-linux-gnu/ld-2.31.so
235,1399,Read map line: 7f8828a000-7f8828c000 rw-p 00022000 b3:02 3339 /usr/lib/aarch64-linux-gnu/ld-2.31.so
235,1400,Read map line: 7fcf71d000-7fcf74e000 rw-p 00000000 00:00 0 [stack]
[BuglyService.cpp][handleSignal][382]Stack is succesfully dumped by libUnwind.
[BuglyService.cpp][handleSignal][384]Native stack:
$$00 pc 0000000002075c80 /opt/QQ/qq [arm64-v8a::e1c1dee543bceb3e3888e876381249a8]
$$01 pc 0000000002075c14 /opt/QQ/qq [arm64-v8a::e1c1dee543bceb3e3888e876381249a8]
[BuglyService.cpp][handleSignal][386]Record map file of thread: 9679
[BuglyService.cpp][handleSignal][396]Dumping of native stack finished.
235,0001,Record EupInfo
235,0002,EupInfo has been recorded.
235,0003,Record native key-value list.
235,0004,Native key-value list has been recorded.
235,0005,Record native log.
235,0000,Native log has not been initiated.
235,0006,Native log has been recorded.
[BuglyService.cpp][clearEupInfo][283]Clear eupInfo object.
235,0005,Try to unlock file: /home/pi/.config/QQ/crash_files//../files/native_record_lock
235,0006,Successfully unlock file: /home/pi/.config/QQ/crash_files//../files/native_record_lock
[BuglyService.cpp][handleSignal][441]Restored signal handlers.
