有 arduinodroid 大神吗? 救急!!!
wwwwww • 2023-01-19 • 3126 次点击
如题,今天准备用华为平板 上传代码到 uno 中 ,第一次上传就报错了,求吧内大神指点一二:
Warning: bMaxPacketSize0 value not passed
Warning: using bMaxPacketSize0=32
avrdude: Version 5.14-arduinodroid (Nov 15 2017)
Copyright (c) 2013-2017 Anton Smirnov
http://www.arduinodroid.info
Copyright (c) 2000-2005 Brian Dean
http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/sdk/hardware/tools/avrdude.conf"
CDC
Using usbfs path : /dev/bus/usb
Using bus number : 002
Using device address : 004
Using Programmer : arduino
Overriding Baud Rate : 115200
failed to set baud rate: -9
avrdude: Sent: 0 [30] [20]
avrdude: usb_fill_buf(): usb_bulk_read() error=-7
avrdude: stk500_recv(): programmer is not responding
avrdude done. Thank you.
错误: Problem uploading to board
Spoony 小组长 2023-01-21
串口的波特率设置问题
wwwwww 2023-02-11
请问如何解决这个问题?
wwwwww 2023-02-11
@Spoony 我使用手机和平板都是会报这个错误,更换IDE 版本也不行
