树莓派 Pico W 初测
店长大人 8.5m • 2022-10-03 • 4002 次点击 • 2 人感谢
8月底海购的树莓派 pico w在漂洋过海一个多月后,终于送到了。今天迫不及待地开始测试。
在网上抄了一个局域网内远程点灯的程序,感觉pico w目前除了生态不如esp外,WiFi连接速度和稳定性,都是极好的,毕竟是英飞凌的芯片,没得说。
![4aa881edc9999af0cea6b8dfa1c40455.jpg](https://ppmm.org/images/2022/10/03/4aa881edc9999af0cea6b8dfa1c40455.jpg)
![4a9596784595f63320b5da59f7ebfb3e.jpg](https://ppmm.org/images/2022/10/03/4a9596784595f63320b5da59f7ebfb3e.jpg)
视频如下:
https://www.bilibili.com/video/BV18e4y1J7mj/ (下方视频如无法显示请点此链接查看)
https://gitee.com/maowenniao/pico-w/blob/master/9c8d787cf996191fe14d6ad833799523.mp4
1:此处下载pico w micropythin的SDK uf2 文件,拖入pico w 中:
https://micropython.org/download/rp2-pico-w/rp2-pico-w-latest.uf2
2: 打开Thonny,将以下代码写入,并保存至pico w,点击运行,记得修改自己的wifi信息。
3:待pico w 连接至wifi后,控制台输出pico w ip, 在浏览器地址栏中输入:
关灯
pico w ip/light/off
点灯
pico w ip/light/on
代码:
import network
import socket
import time
from machine import Pin
### Select the onboard LED
led = machine.Pin("LED", machine.Pin.OUT)
ssid = '你的wifi ssid'
password = '你的WiFi 密码'
wlan = network.WLAN(network.STA_IF)
wlan.active(True)
wlan.connect(ssid, password)
html = """<!DOCTYPE html>
<html>
<meta charset="utf-8">
<head> <title>Pico W test </title> </head>
<body> <h1> Pico W test</h1>
<p>%s</p>
</body>
</html>
### Wait for connect or fail
max_wait = 10
while max_wait > 0:
if wlan.status() < 0 or wlan.status() >= 3:
break
max_wait -= 1
print('waiting for connection...')
time.sleep(1)
### Handle connection error
if wlan.status() != 3:
raise RuntimeError('network connection failed')
else:
print('connected')
status = wlan.ifconfig()
print( 'ip = ' + status[0] )
### Open socket
addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
s = socket.socket()
s.bind(addr)
s.listen(1)
print('listening on', addr)
### Listen for connections
while True:
try:
cl, addr = s.accept()
print('client connected from', addr)
request = cl.recv(1024)
print(request)
request = str(request)
led_on = request.find('/light/on')
led_off = request.find('/light/off')
print( 'led on = ' + str(led_on))
print( 'led off = ' + str(led_off))
if led_on == 6:
print("led on")
led.value(1)
status = "LED is ON"
if led_off == 6:
print("led off")
led.value(0)
status = "LED is OFF"
response = html % status
cl.send('HTTP/1.0 200 OK\r\nContent-type: text/html\r\n\r\n')
cl.send(response)
cl.close()
except OSError as e:
cl.close()
print('connection closed')
来自官方的静态网页代码
import network
import socket
import time
led = Pin(15, Pin.OUT)
ssid = 'Dandandarendewifi'
password = 'yanxiashigeerhuo'
wlan.active(True)
<html>
<head> <title>Pico W</title> </head>
<body> <h1>Pico W</h1>
<p>Hello World</p>
</body>
</html>
max_wait = 10
while max_wait > 0:
break
max_wait -= 1
time.sleep(1)
else:
print('connected')
# Open socket
s = socket.socket()
s.bind(addr)
s.listen(1)
while True:
try:
cl_file = cl.makefile('rwb', 0)
while True:
line = cl_file.readline()
if not line or line == b'\r\n':
break
response = html
cl.send(response)
cl.close()
cl.close()
平头idea 113.2m 2022-10-03
666
店长大人 8.5m 2022-10-03
来自官方的静态网页代码
import network
import socket
import time
wlan.active(True)
<html>
<p>Hello World</p>
</body>
</html>
max_wait = 10
while max_wait > 0:
break
max_wait -= 1
time.sleep(1)
else:
print('connected')
# Open socket
s = socket.socket()
s.bind(addr)
s.listen(1)
while True:
try:
while True:
break
response = html
cl.send(response)
cl.close()
cl.close()
