树莓派重启失败如何解决
yang 10cm • 2022-01-12 • 3449 次点击
sudo reboot后无法正常重启。提示错误:
Failed to open initctl fifo: No such device or address
Failed to talk to init daemon.
用systemctl命令
sudo systemctl reboot
提示错误
Failed to set wall message, ignoring: Failed to activate service 'org.freedesktop.login1': timed out (service_start_timeout=25000ms)
Failed to reboot system via logind: Failed to activate service 'org.freedesktop.login1': timed out (service_start_timeout=25000ms)
Failed to start reboot.target: Failed to activate service 'org.freedesktop.systemd1': timed out (service_start_timeout=25000ms)
See system logs and 'systemctl status reboot.target' for details.
It is possible to perform action directly, see discussion of --force --force in man:systemctl(1).
请问怎么解决
Spoony 小组长 2022-01-12
重刷系统看看
可能是个 BUG
https://bugzilla.redhat.com/show_bug.cgi?id=1937504
