ACT 指示灯
star • 2019-09-26 • 2017 次点击
请问ACT指示灯是处理器哪个管脚控制的呢?
Spoony 小组长 2019-10-14
没有对应的引脚。不过有控制方法:
/sys/class/leds/led0/brightness
# Set the Pi Zero ACT LED trigger to 'none'.
echo none | sudo tee /sys/class/leds/led0/trigger
/home/pi# echo 0 > /sys/class/leds/led0/brightness
/home/pi# echo 1 > /sys/class/leds/led0/brightness
Python 示例:
from time import sleep
led = open('/sys/class/leds/led0/brightness', 'w', buffering=0)
while True:
led.write('0')#turn on
sleep(0.5)
led.write('1')#turn off
sleep(0.5)
