树莓派4连接不了蓝牙设备
目前是小白 70cm • 2021-05-08 • 2630 次点击
配对成功了,但是一连接就显示:
Connection Failed: blueman.bluez.errors.DBusFailedError: No Route to Host, 请问这是怎么回事?
Spoony 小组长 2021-05-08
The solution from this article worked for me:
sudo apt-get install pulseaudio-module-bluetooth
pactl load-module module-bluetooth-discover
Then delete the device from bluetooth devices and pair it again.
If it works, you can consider adding the second command to your startup settings, so that you don't have to run it again after every reboot.
If it doesn't work, try restarting pulseaudio:
pulseaudio -k
pulseaudio -D
https://askubuntu.com/questions/801404/bluetooth-connection-failed-blueman-bluez-errors-dbusfailederror-protocol-no/801669
目前是小白 70cm 2021-05-08
试过了,到pactl load-module module-bluetooth-discover就显示connection refused
