树莓派4B 不不能连接wifi
Charlie_C_ • 2021-03-06 • 1705 次点击
以前是正常的,突然就不能连接WiFi了,
pi@raspberrypi:~$ ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:f0:1e:26 txqueuelen 1000 (Ethernet)
pi@raspberrypi:~$ iwconfig
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
lo no wireless extensions.
/etc/wpa_supplicant/wpa_supplicant.conf这个文件的设置也是对的,求大佬指点
Spoony 小组长 2021-03-08
是装过什么软件或者改过配置文件吗?
如果不确定的话,重装一下系统应该是能恢复的。
