How to use MQTT in Golang
Spoony 81.45m • 2021-01-10 • 1975 次点击
Golang is a statically strongly typed, compiled, concurrent, and garbage-collecting programming language developed by Google. Go is expressive, clean, and efficient. Its concurrency mechanism makes it easy to write programs that maximize the use of multicore and network machines, and its innovative type system enables flexible and modular program construction. Go compiles quickly to machine code, but with the convenience of garbage collection and the power of runtime reflection. It is a fast, statically typed, compiled language, like a dynamically typed, interpreted language.
[MQTT](https://www.emqx.io/mqtt) is a kind of lightweight IoT messaging protocol based on the publish/subscribe model, which can provide real-time and reliable messaging service for IoT devices, only using very little code and bandwidth. It is suitable for devices with limited hardware resources and the network environment with limited bandwidth. Therefore, MQTT protocol is widely used in IoT, mobile internet, IoV, electricity power, and other industries.
This article mainly introduces how to use paho.mqtt.golang client library in the Golang project, and implement the connection, subscription and messaging between the client and the [MQTT broker](https://www.emqx.io/products/broker).
### Project initialization
This project is based on go 1.13.12 to develop and test.
go version
go version go1.13.12 darwin/amd64
This project uses [paho.mqtt.golang](https://github.com/eclipse/paho.mqtt.golang) as MQTT client library, install:
go get github.com/eclipse/paho.mqtt.golang
### Use of Go MQTT
This article will use the [free public MQTT broker](https://www.emqx.io/mqtt/public-mqtt5-broker) provided by EMQ X. This service is based on the [MQTT IoT cloud platform](https://cloud.emqx.io/) of EMQ X to create. The access information of the server is as follows:
- Broker: broker.emqx.io
- TCP Port: 1883
- Websocket Port: 8083
#### Connect to the MQTT broker
package main
import (
"fmt"
mqtt "github.com/eclipse/paho.mqtt.golang"
"time"
var messagePubHandler mqtt.MessageHandler = func(client mqtt.Client, msg mqtt.Message) {‌
fmt.Printf("Received message: %s from topic: %s\n", msg.Payload(), msg.Topic())
var connectHandler mqtt.OnConnectHandler = func(client mqtt.Client) {‌
fmt.Println("Connected")
var connectLostHandler mqtt.ConnectionLostHandler = func(client mqtt.Client, err error) {‌
fmt.Printf("Connect lost: %v", err)
func main() {‌
var broker = "broker.emqx.io"
var port = 1883
opts := mqtt.NewClientOptions()
opts.AddBroker(fmt.Sprintf("tcp://%s:%d", broker, port))
opts.SetClientID("go_mqtt_client")
opts.SetUsername("emqx")
opts.SetPassword("public")
opts.SetDefaultPublishHandler(messagePubHandler)
opts.OnConnect = connectHandler
opts.OnConnectionLost = connectLostHandler
client := mqtt.NewClient(opts)
if token := client.Connect(); token.Wait() && token.Error() != nil {‌
panic(token.Error())
- ClientOptions: used to set broker, port, client id, username, password and other options.
- messagePubHandler: global MQTT pub message processing
- connectHandler: callback for the connection
- connectLostHandler: callback for connection loss
If you want to use the TSL connection, you can use the following settings:
func NewTlsConfig() *tls.Config {‌
certpool := x509.NewCertPool()
ca, err := ioutil.ReadFile("ca.pem")
if err != nil {‌
log.Fatalln(err.Error())
certpool.AppendCertsFromPEM(ca)
// Import client certificate/key pair
clientKeyPair, err := tls.LoadX509KeyPair("client-crt.pem", "client-key.pem")
if err != nil {‌
panic(err)
return &tls.Config{‌
RootCAs: certpool,
ClientAuth: tls.NoClientCert,
ClientCAs: nil,
InsecureSkipVerify: true,
Certificates: []tls.Certificate{‌clientKeyPair},
If the client certificate is not set, it can be set as follows:
if err != nil {‌
RootCAs: certpool,
#### Then set TLS
var port = 8883
tlsConfig := NewTlsConfig()
opts.SetTLSConfig(tlsConfig)
// other options
Subscription
func sub(client mqtt.Client) {‌
topic := "topic/test"
token := client.Subscribe(topic, 1, nil)
token.Wait()
fmt.Printf("Subscribed to topic %s", topic)
#### Publish messages
func publish(client mqtt.Client) {‌
num := 10
for i := 0; i < num; i++ {‌
text := fmt.Sprintf("Message %d", i)
token := client.Publish("topic/test", 0, false, text)
token.Wait()
time.Sleep(time.Second)
#### Test
We use the following code for testing.
package main
import (
"fmt"
"log"
"time"
func main() {‌
var port = 1883
sub(client)
publish(client)
client.Disconnect(250)
num := 10
token.Wait()
token.Wait()
fmt.Printf("Subscribed to topic: %s", topic)
Run code, we can see that the MQTT connection and subscription are successfully, and we can successfully receive the message of subscribing topic.
### Summary
So far, we have completed using the paho.mqtt.golang client to connect to the public MQTT broker and have implemented the connection, message publishing and subscription between the test client and the MQTT broker.
We will publish more articles about IoT development and MQTT, so stay tuned.
https://www.emqx.io/blog/how-to-use-mqtt-in-golang
沐风MWind 63.05m 2021-01-10
有点复杂,先收藏了
