编程的方法添加自己的 Linux 系统托盘菜单
Spoony 81.3m • 2020-12-11 • 1750 次点击 • 2 人收藏 • 2 人感谢
Create a Custom System Tray Indicator For Your Tasks on Linux
![b61ed6a031d92a44b7e2644409dee786.png](https://ppmm.org/images/2020/12/11/b61ed6a031d92a44b7e2644409dee786.png)
### Prerequisites
We are going to build a custom system tray indicator using Python. Python is probably installed by default on all the major Linux distributions, so just check it’s there (version 2.7). Additionally, we’ll need the gir1.2-appindicator3 package installed. It’s the library allowing us to easily create system tray indicators.
To install it on Ubuntu/Mint/Debian:
sudo apt-get install gir1.2-appindicator3
### Basic Code
Here’s the basic code of the indicator:
#!/usr/bin/python
import os
from gi.repository import Gtk as gtk, AppIndicator3 as appindicator
def main():
indicator = appindicator.Indicator.new("customtray", "semi-starred-symbolic", appindicator.IndicatorCategory.APPLICATION_STATUS)
indicator.set_status(appindicator.IndicatorStatus.ACTIVE)
indicator.set_menu(menu())
gtk.main()
def menu():
menu = gtk.Menu()
command_one = gtk.MenuItem('My Notes')
command_one.connect('activate', note)
menu.append(command_one)
exittray = gtk.MenuItem('Exit Tray')
exittray.connect('activate', quit)
menu.append(exittray)
menu.show_all()
return menu
def note(_):
os.system("gedit $HOME/Documents/notes.txt")
def quit(_):
gtk.main_quit()
if __name__ == "__main__":
main()
We’ll explain how the code works later. But for know, just save it in a text file under the name tray.py, and run it using Python:
python tray.py
https://fosspost.org/custom-system-tray-icon-indicator-linux/
