新 Raspberry Pi OS 更新 — 2020.12
Spoony 81.3m • 2020-12-06 • 2716 次点击 • 1 人感谢
Chromium 升级到 84 版本
添加 PulseAudio 声音服务
添加了打印机工具
风扇选项,支持温度阈值和风扇频率设置
https://www.raspberrypi.org/blog/new-raspberry-pi-os-release-december-2020/
Tony 286.95m 2020-12-06
Chromium 终于升级了
Spoony 小组长 2020-12-07
@Tony 是啊,终于。。
happy8 1.2m 2020-12-10
呵呵,升级后,HDMI连接电视,没有声音了
Spoony 小组长 2020-12-10
@happy8 There is one small change to the input/output selector, which is the menu option at the bottom for Device Profiles. In PulseAudio, any audio device has one or more profiles, which select which outputs and inputs are used on any device with multiple connections. (For example, some audio HATs and USB sound cards have both analogue and digital outputs — there will usually be a profile for each output to select where the audio actually comes out.)
要手动设置一下
PulseAudio在哪里进入?
在喇叭图标上点击右键吗?还是以前那样,没变化。
Tony 286.95m 2020-12-10
有打印机工具没有驱动又有什么用...
