macOS 下 sphinx + sphinx_rtd_theme 安装和使用
Spoony 80.1m • 2020-12-03 • 1781 次点击
#### Installing
brew install sphinx-doc
sphinx-doc is keg-only, which means it was not symlinked into /usr/local,
because this formula is mainly used internally by other formulae.
Users are advised to use pip to install sphinx-doc.
If you need to have sphinx-doc first in your PATH run:
echo 'export PATH="/usr/local/opt/sphinx-doc/bin:$PATH"' >> /Users/wangxianyuan/.bash_profile
#### Use sphinx_rtd_theme
Via Git or Download
https://github.com/readthedocs/sphinx_rtd_theme
Symlink or subtree the sphinx_rtd_theme/sphinx_rtd_theme repository into your documentation at docs/_themes/sphinx_rtd_theme then add the following two settings to your Sphinx conf.py file:
html_theme = "sphinx_rtd_theme"
html_theme_path = ["_themes", ]
#### Make
cd ~/docs
make html
