树莓派官方系统 Raspbian 更新(2020-5-27)
Spoony 80.05m • 2020-05-29 • 2645 次点击
2020年5月27号树莓派官方系统更新啦,本次更新的主要特点
1,为了支持5月28号发售的PI4B 8GB;
2,官方系统以后更名为Raspberry PI OS简称RaspiOS,Raspbian的名称已经成为历史;
3,同时官方发布了64位 beta版本系统,下载地址
https://www.raspberrypi.org/forums/viewtopic.php?f=117&t=275370
获得方式 32位 RaspiOS
1,请在网盘资料中 官方系统raspbian百度网盘资料 下载
2,直接官网去下载 https://www.raspberrypi.org/downloads/raspbian/
3,you can use apt to update:
sudo apt-get update
sudo apt-get dist-upgrade
2020-05-27:
* Added Bookshelf application
* Added Raspberry Pi Diagnostics application
* Added magnifier plugin to taskbar - needs magnifier application installed from Recommended Software to enable
* Added Magnifier application to Recommended Software
* Added marketing questionnaire as initial Chromium tab
* Version 0.25 of Scratch 2 included - uses external application to access IMU on SenseHAT
* Version 1.0.5 of Scratch 3 included - uses external application to access IMU on SenseHAT
* Version 32.0.0.371 of Flash player included
* Version 1.0.6 of Node-RED included
* Version 6.7.1 of VNC Server included
* Version 6.20.113 of VNC Client included
* Internal audio outputs enabled as separate ALSA devices
* MagPi preinstall removed and replaced with Beginner鈥檚 Guide
* MagPi weblink removed from main menu
* Chromium made default application for PDF files
* Common icon loading code for lxpanel plugins used
* Italian translations added
* Initial move of mouse pointer to menu button disabled
* Padding at left of menu button removed
* Focus behaviour changed so that focus moves to desktop if no windows are opened - improves reliability of Orca screen reader
* Bug fix - focus bug in volume plugin
* Bug fix - keyboard repeat interval bug in Mouse & Keyboard Settings
* Bug fix - battery detection bug in battery plugin
* Bug fix - spurious active areas on taskbar when plugins are hidden
* Bug fix - occasional crash in file manager on file selection
* Disk ID is now regenerated on first boot
* Updated udev rules
- Remove unused argon rule
- Add vcsm-cma to video group
- Add pwm to gpio group
* i2cprobe: More flexible I2C/SPI alias mapping
* Raspberry Pi firmware 21e1fe3477ffb708a5736ed61a924fd650031136
* Linux kernel 4.19.118
Tony 283.95m 2020-05-29
Chromium是随Raspbian更新的吗?
Spoony 小组长 2020-05-29
@Tony 这个应该是独立更新的
沐风MWind 63.05m 2020-05-30
哦我的上帝啊,它终于更新了
终于有64位的了
