MCC118采集数值波动
tiger9637 15cm • 2020-05-21 • 2663 次点击
新买的MCC118,改安装完毕,没有连接外部信号,显示的数值不断跳动,峰值~1.7v
https://ppmm.org/images/2020/05/21/46f113b35f53af8397d112702c3572cd.png
如果将输入与AGND短接,则呈现震荡的信号状态。
https://ppmm.org/images/2020/05/21/a7adf835d1578c5baa1402fe41400368.png
请问这个问题如何解决?谢谢!
tiger9637 15cm 2020-05-21
刚升级了固件,没什么改善。
pi@raspberrypi:~/daqhats/tools $ ./mcc118_firmware_update 0 ~/daqhats/tools/MCC_118.hex
Checking versions...
Hex file firmware version 1.03
Device firmware version 1.01
Do you want to continue? Press Y to continue, any other key to exit. > y
Erasing...done
Writing...done
Verifying...done
Starting firmware...done
Checking device...firmware version 1.03
pi@raspberrypi:~/daqhats/examples/c/mcc118/single_value_read $ ./single_value_read
MCC 118 single data value read example
Function demonstrated: mcc118_a_in_read
Channels: 0 - 3
Options: OPTS_DEFAULT
Press 'Enter' to continue
Acquiring data ... Press 'Enter' to abort
Samples/Channel Channel 0 Channel 1 Channel 2 Channel 3
283 1.74047 V 1.74062 V 1.74109 V 1.74167 V
MCC中国 5cm 2020-05-21
你好。
如果通道悬空,采集到的数据呈现高阻态,任意电压值都有可能。
为保证测试可靠性,需要将导线插入pin脚后,拧紧螺丝。
tiger9637 15cm 2020-05-21  ♥ 1
谢谢,看来是接触问题,插入拧紧后显示正常了
Channels: 0 - 3
166 4.97113 V 1.74062 V 1.74109 V 1.74678 V
Channels: 0 - 3
275 3.31255 V 1.74062 V 1.74109 V 1.74167 V
Channels: 0 - 3
304 -0.00460 V 1.74062 V 1.74109 V 1.74678 V
康先森 10cm 2020-11-09
你好,小白一个,请教一下你的MCC118怎么安装的,我怎么按照树莓派实验室的步骤安装不成功,得不到浏览器的效果。谢谢 QQ1455672248
